buckarooman
Aug 19, 2015Explorer
Shurflo 5.7 Pump
I have recently installed the camco hot water bypass and the suction with 3 way valve for the rv antifreeze. I have double checked every thing and every thing is installed correct,and no leaks but I am un able to get any pressure out of my pump. I have taken the strainer off and cleaned the in and out ports and no luck, what are the odds my watwr pumps bad and can't get enough pressure to get passed the back flow valve? If so what pump would yall recommend?
