shenandoahvalle's avatar
Aug 13, 2013
Slide issues
We have a 2011 Jayco Eagle 320RLDS that we purchased new in January 2012 and as I travel and camp host I have used it quite a bit. Two of the last three times out, the large slide won't extend...it just clicks. The immediate remedy is RELATIVELY simple but somewhat of a PITA. Lying flat on your back there is a trap door in the belly enclosure material that you open, then you can take a wrench and turn the slide screw a couple rounds, then hit the slide button and it works. The aggravating thing is it takes 10 minutes to take out 10 screws holding the trap door, 20 seconds to turn the screw, and another 15 minutes to put all the screws back in. After the trip to the shop for warranty work I guess I will install a trapdoor in the trapdoor that can just be opened and closed. I like this TT but this is the third time to the dealer for warrantee work in 18 months. The supposedly much lower quality Gulf Stream I had prior to this one was in once in four years for work. Ok, enough whining.
  • Two of us shoved and pulled on it for about a half hour to no avail. I think the screw is going a bit too far then won't engage when I try to put the slide out.
  • shenandoahvalley, we have had the same thing since purchased. Dealer could never get it to repeat so he could not fix it. If you ever find out what is causing it or how to correct the problem then I'd love to see the solution.
    Please put a pic of the trapdoor when you get done. Been thinking of that the past couple of days.
  • Have you ever tried just giving it a shove with someone pushing the button? When my trailer was new the slide seal wanted to stick to the side of the camper and did the same thing. A good shove got it going every time.
