Since we moved to snow country in 2006, I've been battling the winter wonderland with schemes to beat the white one. At first we used a 16'x20' green plastic tarp. I refused to be associated with a blue plastic tarp. That only lasted one winter and was easily abraised. Next came a heavy cotton duck tarp. Ah, a real tarp that could take some abrasion. It's only woe was it was awfully heavy and difficult to put in place by yourself. Then came a pole barn which for permit reasons was made 10 feet wide and 20 feet long. This was more like it. A tight squeeze, but did the job. It also housed just the camper without the truck and our mighty little Kioti.
The thing to note here is the crushed rock floor. This would later become very valuable as to its flexibility.
Then came a 3.5 inch lift and taller tires. Oh-oh. The big white box on wheels is now too tall to fit in the barn. Luckily, I have that tractor and used the box scraper to lower the floor 8 inches allowing the TC once again to fit into the barn.
You just have to keep pulling on that string to make it work. Since our camper is now 15 years old and has no leaks that I know of, it is a prime target for water intrusion so I try to keep it out of wetness.
jefe
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
