canicon25's avatar
canicon25
Solar panel and battery noise
Hello all!
I am running 2 6VDC deep cycle batteries in series on my travel trailer. I recently bought a 120W solar panel that is for a 12V circuit.
I hooked up the solar panel using the charge regulator that came with it. I connected the +VE to the first battery +VE and the -VE to second battery -VE (leaving the interconnecting cable in place). The charge regulator indicated that the batteries were charged and displayed a green light.
I turned on all the lights in the RV and the charge regulator indicated that that the batteries required charging and displayed a yellow light.
A short time later I put my ear to the batteries and I could hear then kind of sizzling. The charge regulator said the batteries still needed charging at this time. I immediately disconnected the solar panel.
The charge regulator has a cutin of 13V and a cutout of 14.2.
My question is why did the batteries start to make a sizzling sound?? When using a solar panel to charge batteries should everything in the RV be turned off? Please help me by sharing your knowledge.
Thank you!
