hcs1947
Aug 20, 2015Explorer
Spray Port has no water
I have a 2007 Kodiak 24RBSL, and it has a Hot & Cold Spray Port on the back, with a quick-connect coiled hose. I can't get any water to come out of it. One would think there is a cutoff somewhere but I cannot find it. Anyone with a Kodiak have experience with this? I have already checked that the valve is not seized on the quick-connect, and have tried both pump from fresh tank and city water hookup and no luck so far. I checked water lines from the furnace cubby under the sink to under the slide, and also inside the water heater/pump recess under the dinette seat, and don't see a cutoff valve anywhere. The hatch where the connection is has a sticker with instructions for draining and it indicates there should be a cutoff somewhere inside, but where??? Any suggestions greatly appreciated.
Carl
Carl
