Stabalizers
wkrp
I have a 26' TT which of course has stabalizers on all 4 corners. I have 2 others which I would like to add.
Behind the rear tires there are brackets on the frame which look like points to bolt up the new ones but they are far back of the center of the trailer. (none in front of the tires).
Is there a "normal location" or "best location" to place the extra jacks?
Thanks,
WKRP
2 REPLIES 2
skipnchar
Close to the axles and attached to the FRAME(not the suspension) is the normal location for removing suspension bounce.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
BillB800si
As close to the tires as possible. Tires are rubber & will bounce easily. Install one stabilizer on each side of the trailer close to the tires and you will notice a big improvement. I also use the BAL tire chocks on each side to stop and back & forth movement.
Click here: BAL chocks
Happy trails,
Bill B. (S.E. Michigan)
2015 Dodge Ram Crew Cab 4x4 Hemi
2016 Rockwood Windjammer 3029W
