wmoses's avatar
wmoses
Suburban oven - repeatedly goes off after a while
I did a search on this forum on this and did not see a clear consensus on this issue, so I thought that I would ask again.
When my wife lights the pilot in the oven, she holds the knob in for 15 seconds or so afterwards then proceeds to set the temperature. After some time (which varies) the oven will go out. This happens every time.
We watched the burner assembly while the oven was one and noticed that while the burner was on (before the set temperature was reached) the pilot light was repeatedly coming on and going out. I expect that when the temperature in the oven reaches the set temperature, the burner flame goes out and, if the pilot is out, it never restarts.
Some responses on other threads suggest that the thermocouple (which controls the gas flow) is too far above the pilot flame and that it should be bent downwards. This is easier said than done using one hand as the assembly is quite stiff and not easily bendable (probably a good thing). Another response said that the control module behind the knob for the oven had to be replaced, and yet another said that the whole oven had to be replaced.
So anyone else have this issue and what was the solution? I'd prefer to not take this in to the dealership although the warranty period is still in effect.
