covered_wagon
Jan 04, 2016Explorer
No except I took the gear heads off and lubed the gears. Poured a little 30 wt. oil down the tubes below the gears. I also lube the lowest bearing inside the electric motor by removing the plastic covers once a year. There is a small weep hole in the motor housing after you remove the cover that allows a shot of oil to hit that bearing.
