jotityra
Aug 21, 2020Explorer
Table top propane grill help needed.
I bought a Blackstone griddle to cook with while camping. I don't really like it but will probably use it for making breakfast only. I bought a hose with the quick connect fitting to plug it into the back of the camper which worked great. Now I bought a cheap mr bar-b-Q grill and thought I would do the same but I'm not sure I can do it with the fittings on this grill. The regulator threads into the burner and there is an orifice on the end so I think I need that connected to the grill, but I want to bypass the regulator on the grill because the camper already has the regulator on it. I'm not sure if they make fittings like I need to go right into the burner to take the place of the regulator.
