โJul-24-2020 05:52 AM
โJul-31-2020 01:35 AM
time2roll wrote:RoyJ wrote:
Correct. C/5 would be drained over 5 hours
That is one very fast Semi to drain the 600 mile range battery in one hour...
OK climbing a hill or even accelerating could well be at the 1C rate for a short time. Although I believe this is all within design specification as long as the battery is kept within proper temperature range.
โJul-30-2020 01:36 PM
Reisender wrote:Rivian at up to 180 is the largest I know in a planned consumer vehicle.
I would think most SUVโs wonโt see batteries bigger than 100 - 120 KWh and even vehicles like Cybertruck and Hummer wonโt go much above 220-240 KWH. When they start to shoot for the 3/4 ton or 1 ton market that might change someday but I havenโt seen anything like that on the drawing board yet.
โJul-30-2020 01:33 PM
โJul-30-2020 11:48 AM
RoyJ wrote:
My concern is the speed at which the pack is drained - nearly 1C. This is very hard on a big battery pack.
Batteries from lead acid to lithium are used in plenty of heavy duty applications, but they're sized for closer to C/4 to C/12 rates.
That's why I mentioned 1000 kWh - at that size, we could tow a regular commercial travel trailer and maintain say, a C/5 rate of discharge. Ideally you'd arrive at a campsite and charge overnight at C/10 rate. Not being blasted by a supercharger at 1C+
โJul-30-2020 11:30 AM
โJul-30-2020 11:27 AM
โJul-30-2020 11:14 AM
โJul-30-2020 06:25 AM
RoyJ wrote:
This hasn't been mentioned yet - but wonder if constant heavy discharge, followed by fast charging, will take a toll on battery life. Much more so than an IC engine running high duty cycle.
I'm far from anti-EV, in fact, I believe 99% (not an exaggeration) of commuting should be done with EVs.
But the fact is battery technology is not quite there yet to support heavy duty-cycle. The motors are, and have been ever since GM introduced the first diesel-electric locomotive. 99.9% of rail freight use electric motors for motive, the <.1% being heritage steamers.
As soon as we have reliable 1,000 kwh battery packs, with negligible Peukert factor, then bye-bye ICs.
โJul-30-2020 05:59 AM
โJul-30-2020 05:37 AM
โJul-29-2020 11:17 PM
โJul-29-2020 03:19 PM
Me Again wrote:
All I can say about those 57' 5th wheel with the axles near the rear, one will have to learn to really swing their corner wide. There are many tight area that they will not go. Maybe the trailer wheels are steerable and the DW rides back there with a second steering wheel.
โJul-29-2020 03:09 PM
โJul-27-2020 06:18 PM
qtla9111 wrote:8.1 Van wrote:
Here is what you will be able to tow next year with a Tesla .;)
Tesla Semi: the electric semi truck is going to be built in Texas
Do you have a link to this fifth wheel? Man that thing is huge!
