ret_usn's avatar
ret_usn
Thermostat change.
Changed my original thermostat to a Honeywell programmable on. added the switch for high speed fan. works great and easy mod
  • I changed mine out back in 2008 W/O adding the switch...just wired it for HI Speed all the time.
    NEVER used LO Speed anyway
  • DW says we may use slow speed sometime so that is why I installed the switch. it comes on at low unless the switch is on.
    Only tine sliw can be used is in fan only setting
  • My test show the switch will control fan speed in either heat or cool mode with thermostat set on auto fan.
