RoyJ wrote:
You make some very good points, and have done more research than many people on the relationships of GAWR/GVW. However, if you read what 12V98 wrote again I don't think he was disagreeing with you.
It's possible you may be more in tune with his posting style and saw his perspective more clearly. I don't post on rv.net all that regularly, so I took his posts at face value.
RoyJ wrote:
He simply pointed out that The GVWR is often artificially restricted to less than the sum of front + rear GAWRs. So in a way, you can safety exceed your "payload" or GVW, as long as your axle weight are in check (which it is).
That's one thing I find annoying in the non-commercial world. With heavy trucks, GVW is almost always sum of all GAWRs (up to the federal / State limit). You'd never see a Kenworth with 12k front axle, 40k rear tandem, and some arbitrary 49,500 lbs GVWR.
I always tell people GAWR is a true engineering spec, as it encompasses suspension, braking, axle bearing, and tire loading. GVWR is marketing / legal driven. If you don't exceed your GAWRs, then you can safely exceed GVWR. No I'm not a lawyer, but as an engineer, I'd happily act as the expert witness in court, if someone ever got sued for being over GVW but under GAWR (not aware of one).
Appreciate your explanation. I was already well aware that the sum total of the FAWR and RAWR exceeds the GVWR on many trucks (and cars, for that matter). As many of us know, this is especially true for many late-model, 3/4-ton diesel trucks. Many are "administratively" limited to a 10k GVWR for registration purposes (and have a very low payload rating as a result)---even though the axle ratings are very similar to their 1-ton SRW stablemate. Easy to understand why some may choose to ignore the payload or GVWR and focus on the FAWR and RAWR.
However, (as you suggested) if one chooses to ignore the payload/GVWR on
any truck, they may open themselves up to the possibility they may have to call an expert witness, such as yourself to, hopefully, convince the court the GVWR is indeed, just a marketing gimmick---a paper tiger.
For my peace-of mind (and with all due respect for your engineering expertise), I chose to pay the higher registration fees and purchased a 1-ton SRW (vs. a 3/4-ton) so I can stay within
all the truck's ratings. No expert witness necessary.
