Terry26's avatar
Terry26
Tire pressure & too many blowouts
Hi, I have a 2000 Fleetwood Terry 26' trailer camper and only used 4 times in four years i had a blowout on each trip! My camper has a tandem axle.
The factory sticker on the camper states:
GVWR: 8300 lbs
GAWR: 4300 lbs
Tires: ST225/75R/15C
Tire pressure; Cold/50 lbs
I installed 4 new tires when I bought the trailer and are the size shown on the sticker and are ST with load range D. Of course since then an additional 4 new tires.
I always felt 50 lbs was far less psi than proper but when I had the tires installed the tire man said he filled them up to the factory recommended specs. I looked at the tires and told him that on the tires its states 65 psi cold. Could this be my problem with blowouts? Too little psi? I've never pulled the trailer with any appreciable extra load. All water and waste water tanks empty, just clothes and food. I tow the trailer level, and use load leveling bars and anti-sway bar, I rarely exceed 65pmh and have never traveled mor than 350 miles to a destination but had blowouts after as few as 70 miles.
Thanks
