Aug-07-2014 11:34 AM
Aug-08-2014 10:29 AM
Aug-08-2014 09:37 AM
majorgator wrote:
To the OP, i thnk you answered your own question in your first post: just went 10K miles and tires are doing well. Enough said 😉
The difference in between the 2 tires is negligible, as shown. There's lots of good theory and practical knowledge given by the other posters here, which would be good to heed if you had a significant tire size difference. But you don't, so don't worry about it. I would simply make sure that the axles have matching tires, not that one side has matching tires. You know, some BMW's and other high end cars have different tire sizes from front to back...
Aug-08-2014 03:54 AM
Aug-08-2014 03:35 AM
Aug-08-2014 03:33 AM
budwich wrote:
Interesting about the weight shift during braking. Hopefully we are talking about the trailer suspension equalizer and not a hitch equalizer. Not sure I understand how the brake event cause the weight "lift" in the equalizer of the suspension. My thinking was that it would reduce / slightly lift the rear axle.
I am also wondering if there would be any affect on tongue weights with the larger tires moved to the forward axle.
Aug-08-2014 02:30 AM
Aug-07-2014 07:29 PM
Aug-07-2014 05:58 PM
Aug-07-2014 03:59 PM
RCMAN46 wrote:
Put the trailer on flat level ground. Measure height to the frame between the axles for each side.
I would put the same size tire on a side and then depending on the height measurement which side to put the taller tires.
As for handling etc I doubt it will make much difference with the tires as close as they are.
Aug-07-2014 03:53 PM
johntank wrote:
Diameter inches (mm)
26.11 (663.1) 26.7 (678.1) 0.59 (15) 2.3%
Width inches (mm)
8.07 (205) 8.46 (215) 0.39 (10) 4.9%
Circum. inches (mm)
82.02 (2083.19) 83.87 (2130.31) 1.86 (47.12) 2.3%
Sidewall Height inches (mm)
6.05 (153.75) 6.35 (161.25) 0.3 (7.5) 4.9%
Revolutions per mile (km)
772.54 (480.03) 755.45 (469.41) -17.09 (-10.62)
The first numbers are for the 205 tires and the second set are the 215 tires the third is the difference.
My opinion would be to have the 205's & 215's on the same axle.
Aug-07-2014 02:08 PM
Aug-07-2014 12:10 PM
Aug-07-2014 12:04 PM
Aug-07-2014 12:00 PM
