DirtyOil wrote:
Pot callin kettle black?... you talk the talk... a "2-way" cat does remove some of the NOx... and I said "some" until the 3-way cat was introduced which removed more NOx albeit only by some 8-9%.
The two way only removes hydrocarbons and carbon monoxide which is why they call it a two way since it only removes two pollutants. The three way catalytic converter removes hydrocarbons, carbon monoxide, and NOx. (You want a hint as to why they call it a three way catalyst?) Diesels cannot have a three way catalytic converter because a three way requires the engine to run at a near stoichiometric (14.7:1) air/fuel ratio in order to work while a two way does not. Gasoline engines constantly operate at stoich(or very close to it) while diesels don't which is why you will never find a three way catalytic converter on a diesel and only a two way since it does not require the engine to run at a stoich air/fuel ratio to do its job. So no, your assumptions are wrong again. Sheesh, you would think you would give up already after being proven wrong so many times.
DirtyOil wrote:
So... who's making the assumptions here?
Look in the mirror...
DirtyOil wrote:
New diesel engines in OTR vehicles are still putting out as much nitrogen oxides now as they did 15 yrs ago!
Please re-read what Turtle N Peeps, Jus2shy, Sport45, and myself have been posting. If you cannot understand it then please feel free to reread it over and over again until you do.
DirtyOil wrote:
Shut down all industries that use fossil fuels to produce their products, then get all those homes that burn fuel oil to heat their homes to stop (can't use firewood or coal as they also contribute nitrogen oxides) shut down all trains, planes and automobiles... all contributors... there ya go Shinner some worth standing on yer soapbox about... but then your as dirty as the rest of us! :B
Not once did I say that we should go to those extremes. NOT ONCE. So where you are getting this from is beyond me. All I have been saying is that these emissions devices are there for a reason, and removing them is careless, selfish, and irresponsible. These emissions devices are on these trucks so we don't have to go to the extremes that you just mentioned above. However, some think they are above everyone else and do not care if their choices of deleting these devices effects anyone. All they care about is themselves.
DirtyOil wrote:
Sulphur is used in fertilizers, Shinner would have us not use it either, as Sulphur breaks down and mixes with the available Oxygen then we get all those nasty pollutants.
I never said that either. Man, where are you getting this stuff from? Is all these deleted diesel emissions finally getting to you and making you read things that aren't even there. Sheesh, the lengths you will go to to justify you illegally taking off your emissions devices and purposely causing more pollution just for your own selfish reasons.
