โJul-24-2017 07:10 AM
โJul-25-2017 04:13 PM
dave54 wrote:
The downside to max sidewall PSI is when you unhitch. Running around locally with little to no weight and tires inflated to max is the vehicle will ride like a army tank.
Doesn't really hurt the vehicle, but the occupants will be bounced around like peas in a kettle drum.
โJul-25-2017 04:08 PM
โJul-25-2017 03:43 PM
โJul-25-2017 02:05 PM
โJul-25-2017 11:56 AM
โJul-25-2017 09:51 AM
โJul-25-2017 09:11 AM
โJul-25-2017 09:10 AM
shemphill wrote:
I've noticed the tires on new TT's are barely enough to carry the GVW. Potholes, those new vertical handicapped curbs, debris, etc. can easily throw the dynamic load well above the tire ratings. I've been hearing that LT tires are a good upgrade. Anybody have any experience with them?
โJul-24-2017 10:13 PM
โJul-24-2017 10:03 PM
bguy wrote:coolbreeze01 wrote:
Max psi allows the tire to carry its max rated load. Low psi causes heat buildup in tires and heat kills tires.
Your tire is rated to carry somewhere around 2600lb @44PSI cold. Less
PSI = less capacity.
โJul-24-2017 12:45 PM
โJul-24-2017 09:56 AM
โJul-24-2017 09:26 AM
cjunken wrote:
So truly the only safe bet would be to load up and get it all weighed to really verify how everything sorts out. I have a pic of my tag and looks like front axle rating is 3100 and rear axle is 3300. Cold pressure is listed at 35 but sidewall max says 44. So I'm thinking that I'd like to bump that up to about 42 at least. It didn't ride horribly on the interstate but I'm hoping that a 20% increase in pressure may stiffen up the ride a bit.
โJul-24-2017 09:18 AM
