Don't give up on the F150 'cause yours had the weakest numbers....if your a Ford fan.
Fords F150 has over a dozen different GVWR ratings....4 different RAWR packages.
Of course you know what your F150 numbers are.
But from the top;
#1. 7850 gvwr...4800 rawr....2500 lb in the bed payloads.
#2. 7600 gvwr...4550 rawr... 2200 lb in the bed payloads
#3. 7050 gvwr...4050 rawr... 1800 lb in the bed payloads
#4. 6800 gvwr...3800 rawr...1500 lb in the bed payloads.
#5 . yours
And you can get any of them with the 3.5 ecoboost engine that has 375 hp and a butz kicking 470 lbs torque. And those that own them say they get 20s mpg out on the road not towing.
Ram
Of course the Ram with the 5.7 hemi 4wd crew cab 3.92 gears 8 speed tranny at 395 hp and 410 torque. The 2020 1500 has a 7100 gvwr and 4100 rawr with a 11k tow rating. No problems with the size trailer your looking at.
Chevy/GMC...
1500 crew cab 4wd NHT tow package has the 6.2 engine at 420 hp and 460 torque with the 10 speed tranny 7300 gvwr and 4150 rawr. GM says up to 13400 lb tow rating. The same truck with the 5.3 v8 at 355hp and 383 torque 10 speed tranny won't have any issue with that size trailer.
And of course the 3/4 ton....or one ton SRW and I'm surprised some one hasn't said you gotta' have a one ton DRW.
Go shopping and drive all of them. LOL...we would love to spend your money :B.
1500 GM specs
chevy ordering guide Fleet ford specs
clicky link Ram body builders guide specs
ram clicky link
