Dec-31-2018 04:41 PM
Jan-06-2019 08:50 AM
Atlee wrote:
If you don't own a 3.5L Ecoboost, how do you know that engine is worked to death, and it's insanity to try to do so?
I also have a F150 HDPP and 3.5 Ecoboost. This past summer, we traveled from Virginia to New Mexico, Colorado, Utah, Idaho, Wyoming, Montana, and South Dakota before coming back home.
We were in the Rockies a lot. At no time was my 3.5L Eco every over worked going up the steep grades. And when I had to slow way down until a slower vehicle got out of my way while going up a steep grade, I had zero problem getting from the low speed back up to the speed limit. And no, the engine was not screaming while doing so. Usually, 3500 rpm was all I needed to get back to speed.
The only problem was going down steep grades. I really had to manually down shift sometimes to 2nd gear to keep my speed down and not have to use too much braking.
Now, I would not begin to tow 10k GVWR trailers with my 3.5L F150.
My trailer is 6500# GVWR and it worked fantastic behind my F150 3.5L Eco w/ HDPP.
Jan-02-2019 11:44 AM
Jan-02-2019 09:20 AM
Jan-02-2019 08:51 AM
Jan-02-2019 08:43 AM
JIMNLIN wrote:
snip....
Ford markets several gvwr/rawr packages for the F150;
#1. 7850 gvwr...4800 rawr....2500 lb in the bed payloads.
#2. 7600 gvwr...4550 rawr... 2200 lb in the bed payloads
#3. 7050 gvwr...4050 rawr... 1800 lb in the bed payloads
#4. 6800 gvwr...3800 rawr...1500 lb in the bed payloads.
Payloads are a estimate as only scaled axle weights will give any truck its real world payloads.
Jan-02-2019 08:19 AM
Eric 18 wrote:
Thank You All for the responses!
I'm pretty set on truck size. I'll be buying new. We're going to go with a lighter weight trailer, per the majority of thoughts.
The truck will be my daily driver, and will be trading in a 14 GT Mustang for it.
My wife & I love the sense of community we find RVing. It seems to be the same here!
Thanks Again, Happy New Year!
Jan-02-2019 06:53 AM
Just to clarify, you're mixing up the F150 packages.
The HD Payload package gives you the beefed up suspension for a heavier PAYLOAD capacity.
The Max Tow package gives other features for a higher TOWING capacity, like rear view camera and 36 gallon fuel tank.
With the HDPP, I believe it automatically comes with the Max Tow package.
Jan-02-2019 06:21 AM
I think you're on the right track here. If you get a 3.5 ecoboost and a heavy duty package you should be set. It may not get the greatest mileage while towing but would be a lot better than a gas 3/4 ton when empty. If you're getting a bumper hitch camper make sure you get the rear view camera. It makes it so much easier when you're hitching it by yourself.
Couldn't more strongly disagree with this if I tried. Towing anywhere close to what they say you can tow with a 1/2 ton truck is scary. Doing it with a 3.5L V6 in insane.
I don't own one, but from what I have read online, the engines are worked to death even empty. I doubt you'd see more than 1-2 mpg over a 3/4 ton gasoline truck empty. And the torque difference, loaded or unloaded, is not trivial.
Do the research on what people really are getting for fuel mileage with these things. The ecoboost is not doing any better in the real world than a small V8.
From those of us who own and operate the 3.5L EcoBoost it is not 'worked to death'. I came from a Chev 8.1L (good engine) so I am familiar with good V8s. In the recent post on the Ike Gauntlet you can see the EcoBoost pull the hill at more than 1,000 rpms less than the 5.7 and 6.2 V8s. And I can tell you I really like how it runs at those lower rpms and holds the gears due to the low end torque. The EcoBoost does not have as good of engine braking. Again as seen on the Ike run it had the same number of brake applications as the V8s but was running at higher rpms. This seems accurate to me based on my real world experience.
As for handling payload the Max Payload / HD Payload with the higher GVWR is a more capable truck than a 'typical' 1/2 ton. Let me be clear this does not make the truck an F250, but it is none the less very capable. I have towed 8k for 6 years with no complaints. If I was going to go heavy with a new F150 I would seek advice from someone doing this in the real world on this forum.
As for mpg it gets the same as V8s towing and I get 19mpg with the 3.73 running at 65mph. I would expect the newer trucks do a bit better.
Take it easy,
Stu
Jan-02-2019 06:16 AM
Jan-02-2019 06:03 AM
Jan-02-2019 04:21 AM
Jan-01-2019 04:32 PM
bikendan wrote:AlmostAnOldGuy wrote:
Pulling 8k I get around 9.
If you have good reasons for staying with a '1/2 ton' and go with an F150 I would get the Max Payload option to beef up the suspension. Those are tough to get on a lot so that means putting in an order for your truck. That also means you get just the packages you want. Would not expect to save any $ over the F250. But you may have other reasons for staying with the F150 (vehicle height, non-towing mpg, etc.).
Good luck,
Stu
Jan-01-2019 04:11 PM
Jan-01-2019 11:45 AM
Jan-01-2019 09:22 AM
