Feb-13-2016 06:59 AM
Feb-14-2016 10:15 AM
Rally's attended so far-21
Feb-14-2016 10:08 AM
RinconVTR wrote:It may be a non-issue with a Tire Minder, it is not a non-issue with other brands.minnow wrote:Searching_Ut wrote:
Unfortunately I think most TPMS operate as you're describing. If they're maintaining radio contact they are reasonably quick to inform of issues such as low pressure, overheat etc. If they loose signal, it just reports last received signal while waiting for an update. In this situation it takes about an hour for it to report a fail. If you simply get intermittent signals, with temporary reception every thirty minutes or some other value less than an hour you'll never know you have shoddy reception. I put a repeater on my TST 507 system because of this but I still don't really know if I'm getting a reasonably consistent signal or not.
If that is the case, then what's the purpose of even having this unit? Tire blows out, and one might not know about it for an hour ?
You're overacting to a non-issue.
I have used the Tireminder system and it did the same thing.
When the unit powered up, if it did not read any sensors, the readings would lock and only occasionally go blank. If it picked up just one sensor, that one would go live and the other 3 blank.
I would often lose the signal to one of the rear trailer tires and it would report immediately. If I gave the receiver to my son in the back, that 5-7 feet distance change was enough to quickly regain the signal. I needed a repeater or booster to fix this, even though my TT is only 26' bumper to ball.
There is very little delay when you are actually driving and its sensing at least one sensor...or not.
Feb-14-2016 09:00 AM
Feb-14-2016 07:14 AM
Feb-14-2016 07:05 AM
rtate wrote:What you're saying is unclear. You repeat TPMS when I think you're referring to your brand name. TPMS means T(ire) P(ressure) M(onitoring) S(ystem). Could you specify what brand you have, i.e. TST, Tire Minder, Pressure Pro, etc.?
Wow! When I was considering A TPMS I asked for advice on which brand to purchase. The response from most everyone on this board was TPMS. After purchasing mine it appears no one likes their TPMS.
Oh well. I guess the advice was worth what I paid for it.
Feb-14-2016 06:58 AM
Feb-14-2016 04:58 AM
Feb-14-2016 04:46 AM
Feb-14-2016 04:35 AM
Feb-13-2016 12:24 PM
Feb-13-2016 10:33 AM
EV2 wrote:That should be the way they work, but not all work that way. Some have a time period of up to an hour after they fail to receive a signal before they report that loss of signal.
Without knowing your brand and model, we can only generalize. If you had only one sensor your scenario could possibly exist, but when moving the sensors update the info quite frequently. If one sensor updates, the software expects all of the sensors to update. If one does not report a flag is set to notify that the sensor is missing.
Feb-13-2016 10:29 AM
rtate wrote:agesilaus wrote:
Is this system wired? Unlikely, it is probably wireless and uses a radio signal. So even if the trailer is unhooked you may still be close enough to pick up the signals from the trailer tires.
The brand is TPMS, model 536. I drove fifty miles away. Don't think it was still picking up from the sensors.
Feb-13-2016 09:04 AM
Feb-13-2016 08:27 AM
Feb-13-2016 08:24 AM
