Sam_Spade
Mar 25, 2017Explorer
Alaskan Fly Guy wrote:
My travel trailer does not seem to be charging from the tow vehicle while traveling. I think I may have a bad 20A fuse for the "tow battery charge". There are 2 choices for these fuses. A tall one and a shorter one. Which one do I get for my 2003 F-250? Thanks in advance.
Which ever 20 amp fuse will fit properly; same size electrically and physically as what's in there now.
BUT....words like "seems to be" and "I think" indicate that you are going about this wrong.
Get a multi-meter and check the fuse and then check the voltage on the charge line at the trailer and then at the trailer's batteries. Then you will KNOW what the situation is and won't have to guess, at least not so much.
44,026 PostsLatest Activity: Feb 24, 2025
