norcal10's avatar
norcal10
Trailer Running Lights Issue
Hi everyone,
I recently acquired a 1979 Nomad 23ft trailer. However, I can not get any of the trailer lights to work. No running lights, tail lights, clearance lights or electric brakes. The only light that works is the passenger side turn signal. I've cleaned every light, tightened the grounds on them, cleaned the ground from the 7-way that is grounded on the trailer frame, sprayed the pigtail with WD-40, bent the prongs just a tiny bit so they fit tighter, but still the only thing that works is that passenger turn signal. Ive tested the lights with a probe tester and the only one getting power is that passenger turn signal.
Im running out of ideas. I'd appreciate any advice that you guys and gals have to offer. Electrical is not my strong point.
Thanks everyone!
