Transmission Temperature - 2009 T&C
Thomson7
I just installed a transmission temperature gauge in our T&C to monitor the temp during towing. But I have no idea what a normal temperature should be. Is it influenced by ambient conditions? What should the "red-line" be before we pull over and let it cool down? Any input, or suggestions of where to find answers would be helpful!
15 REPLIES 15
Thomson7
Well I think we're good. Transmission Temp was 150-175 normal driving and only hit 190 after 10 minutes of steep up hills. Feeling pretty good about that.
ib516
Thomson7 wrote:
I wish I'd gone that route now. Would have been cheaper in the long run!
If you're talking about the Scangauge2, don't fret - it may not work for your vehicle, so you may have gone the correct route.
There are a limited number of Chrysler products it will read. I tested the codes for them, and mine is one that it does indeed work with.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
Tystevens
Turtle n Peeps wrote:
jrw1550 wrote:
Goldstalker and Mark you both gave an answer but did not provide anything to support it. Why was it comical and why does it not apply for modern transmissions. I am under the impression that heat is the number one enemy of transmissions. do the modern ones do something different in that regards. A little more information would be most helpful. Thank you.
#1. ATF is night and day difference from what it was in the 60's.
#2. Seals are made out of waaaaaaaaaaaaaaaay better material than years ago.
#3. Coolers are huge now days.
#4. Tranny's lock up 1 to 1 now days to keep heat down.
#5. It is just some chart apparently made by someone selling transmission coolers!
Refer to your owners manual for what is acceptable for your vehicle, not some chart made by some guy on the internet trying to sell you something!
BTW, thanks for the insight as you your engineering experiences, Mark. Very informative!
2008 Hornet Hideout 27B
2010 Chevy Suburban 1500 LT, Z71 package, 5.3/6A/3.42
2015 Ford F150 XLT Supercrew, 2.7 Ecoboost/6A/3.55 LS
Prior TVs:
2011 Ford F150 Ecoboost 3.5
2006 Chevy Silverado 2500HD Duramax LBZ
2005 Chevy Suburban 1500 4x4 LT, 5.3/4A/4.10
Thomson7
Mark_Kovalsky
Materials used to construct automatic transmissions have been greatly improved since the 60's when that chart may have been somewhat accurate. ATFs especially only resemble their predecessors in that both are red. Modern ATFs can run as hot as 220°F all day and all night long and still last longer than earlier fluids that stayed at 150°F. I've tested modern ATFs over 300°F and they didn't burn up like that chart implies. That doesn't mean I recommend running your trans that hot, but doing it won't kill it.
I've seen a test transmission that ran VERY hot, but didn't fail. The gauge we had only went to 320°F, but solder melted out of the solenoids. The solder that was used to construct those solenoids had a melting point of 450°F. So we know it got at least that hot, maybe hotter. The trans still worked and the fluid was not destroyed, but definitely showed some discoloration from the heat.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
ib516
Read Mark's signature. "Former transmission engineer". From reading his posts over the years, he clearly knows what he is talking about when it comes to transmissions. I'd take what he says at face value, though I'll agree more of an explanation would be helpful to educate the rest of us. :B
ib516
Thomson7 wrote:
ib516, when you plug the scan gauge in, does it not put the computer in a sort of diagnostic mode? I thought that was part of the problem with using those sorts of systems to monitor performance... the vehicle doesn't enter a "normal" condition.
Nope, the ecm has that data in the can bus data stream anytime the truck is running. All the Scangauge does is passively read it.
gmc6000
Typically 100 degrees above ambient temperature is normal operation.
2017 Ram 3500 DRW Laramie MegaCab 6.7 Aisin 4:10
2013 KZ Inferno 3710T
Turtle_n_Peeps
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Thomson7
jrw1550
Mark_Kovalsky
BigGrey wrote:
See if THIS LINK HELPS
That link may have been true 50 years ago, but it has no basis in reality for modern transmissions and transmission fluid. That link means NOTHING.
Mark
Goldstalker
I find that link comical.
2007 GMC Sierra 1500 Crew Cab Z71 4X4 3.73
2013 CrossRoads Sunset Trail Super Lite 250RB
2-2012 Yamaha VX Deluxe
2012 Toyota Highlander
BigGrey
John
2009 F350 DRW CC, 2012 Airstream Flying Cloud
