jrw1550 wrote:
Goldstalker and Mark you both gave an answer but did not provide anything to support it. Why was it comical and why does it not apply for modern transmissions. I am under the impression that heat is the number one enemy of transmissions. do the modern ones do something different in that regards. A little more information would be most helpful. Thank you.
Materials used to construct automatic transmissions have been greatly improved since the 60's when that chart may have been somewhat accurate. ATFs especially only resemble their predecessors in that both are red. Modern ATFs can run as hot as 220°F all day and all night long and still last longer than earlier fluids that stayed at 150°F. I've tested modern ATFs over 300°F and they didn't burn up like that chart implies. That doesn't mean I recommend running your trans that hot, but doing it won't kill it.
I've seen a test transmission that ran VERY hot, but didn't fail. The gauge we had only went to 320°F, but solder melted out of the solenoids. The solder that was used to construct those solenoids had a melting point of 450°F. So we know it got at least that hot, maybe hotter. The trans still worked and the fluid was not destroyed, but definitely showed some discoloration from the heat.
