- GilliedogKiwiExplorerWhat kind of hitch do you have - you say take it off before backing up? We have the Reese Straightline hitch with the camlocks and you don't have to get out and unhitch anything at all - its wonderful.
Angela - Wpk109ExplorerThanks for all the feedback everyone. I'll be greasing up this weekend! And yes, I do take off the sway bar before backing in/turning sharply...had a really good mechanic set me up at Grumbine's RV in Harrisburg, PA. He was really throrough and really knew his stuff!
- Roundtwo-40ExplorerWe LOVE ours, it rained our last trip out and the boys both had their space and DW and I relaxed and did our own thing (knitting and reading). We looked at each other and both said "we made the right decision" I dont think it is right for everyone, but it sure works for us :) Thanks for the post :)
Happy Camping! - waynec1957Explorer
Roundtwo-40 wrote:
Are you using a weight distributing hitch with anti sway bars? If so that is what is probably creaking, mine has friction bars that rub metal on metal.
This is way off topic, and I apologize in advance, but I gotta tell you we looked at that Jayco Eagle 328RLTS at the Indianapolis RV show a few months back and absolutely LOVED that rig. Those opposing super slides make that front living space HUGE. Awesome camper.... - LakeNExplorer
RedRocket204 wrote:
sbowman871 wrote:
Grease the trunion ends on the weight distribution bars.
Yup. I make it a habit of new grease on the spring bar connections to the hitch as well as the ball every time I hook up. Then a couple of paper towels to wipe off the grease when I unhitch. Wiping off the grease avoids making a mess as well as always having fresh grease the next hitch-up.
Ditto - DE88ROXExplorer"Its just your normal noises in here" Tom Petty
Its going to creak to some degree depending on what you have greased. remember that the bars and chain are under a great deal of tension.
Like other have said, grease the bars ,NOT THE ANTI-SWAY BAR where they hook onto/into your hitch. You will see a dramatic difference in noise.
Also, you might want to make sure that you remove the anti-sway bar prior to backing in. I usually take mine off while im stopped and checking into the campground. - CavemanCharlieExplorer IIIMy suspension creaks and groans. If I put a drop of oil on the points where the center hanger thing moves then it quits for a month or so then starts back up again.
- RedRocket204Explorer
Yup. I make it a habit of new grease on the spring bar connections to the hitch as well as the ball every time I hook up. Then a couple of paper towels to wipe off the grease when I unhitch. Wiping off the grease avoids making a mess as well as always having fresh grease the next hitch-up. - colochoclabExplorerOurs makes a racket, especially at slow speeds. It is indeed the EQ hitch creaking and groaning, it is normal. I use the "Sway Bracket Jackets" on my Equalizer and it helps a bit.
- goducks10ExplorerMake sure you lube the short end of the spring bar that slide up into the WD head.
About Travel Trailer Group
44,030 PostsLatest Activity: Jan 21, 2025
