budwich
Sep 16, 2016Explorer
mntnv7231 wrote:
It was plugged into the house long extension cord was used, smaller amp cord there is power to that outlet have cycled on and off all Breakers still nothing I replace the GFI it is still tripped
unplug the microwave. does the gfi still trip? IF so you know it is NOT the microwave. You then need to check the receptacle where it was plugged in to ensure that the wiring is not touching anything there in. With trailer movement, receptacles and wiring in them can move / loosen causing issues.
44,029 PostsLatest Activity: Jan 19, 2025
