Bedlam
Oct 09, 2019Moderator
My last fridge was three way and would switch back forth between AC and LPG on the automatic setting without a problem. If AC and LPG were not available, it would switch to DC but would then stay there until you manually switched it out of that mode. I could run the fridge in manual mode choosing my source so it would not switch over but had to be careful with the automatic setting. Once while driving in high winds, the LPG flame blew out and it switched to DC and another time I ran out of LPG and it switched to DC. My previous camper did not have solar and only had the small charge line on the 7-blade connector, so I was drawing more than I was replenishing from the truck.
Running AC or or heavier DC from the truck would have solved my previous problem but by the time I experienced it the the first time, I already had upgrade plans for the truck and camper...
DC source was convenient for restricted LPG use areas like tunnels and ferries, but I passed on the option this time. I like some of the compressor fridges offered but still have a hard time justifying the price. Perhaps if my absorption fridge fails, I will revisit that option. Although I have seen some of the pictures of LPG fires caused by appliances, I am still confident in my systems to use them while driving.
44,055 PostsLatest Activity: Dec 23, 2025
