Truck shopping 04-07 model years. Advice please.
orange_jordy
I am just starting to shop for a truck to replace my current 2006 Ford F150 supercrew. The truck has been unreliable for the last two years and the wife would like me to get rid of it so she feels more secure when we go out camping next summer. The thing is for us (and probably most folks) money is tight and we can't afford a monthly payment on a new truck so we decided to look at the previously owned market. I have only done some online browsing and not actually gone to look at anything yet. Our camper is the same one we have had for years(Gulfstream Amerilite 24RS, 7400 lb gvwr) and it meets our needs for now and the future so we have no plans to upgrade at this time, however we have talked about getting a truck that is large enough to comfortably step up to a larger camper without having to upgrade the truck. From the bit of reading I have done, I am looking at trucks in the 2004 to 2007 model years and I am looking at 3/4 ton and 1 ton both gas and diesel. The wife will not let me look at another Ford so I guess I am looking for information on Dodge and GM trucks from those model years. I am not biased toward one brand over the other, I am just looking for the best truck for my money. I have never owned or driven a diesel truck before so I don't know much except that in the years I am considering people seem to like the 5.9 Cummins and the Duramax LBZ. I know the 5.7 Hemi and 6.0 Vortec are strong gasoline engines as well. I will be using the truck as a daily driver to work(25 km each way on the freeway)as well as towing the camper during the summer. We mostly do shorter trips ,under 1000 km round trip, but we have discussed doing a couple of trips that would take us up to 6000 km total. If I could get some pointers or pros and cons from people that have owned or operated trucks in these years, it would be greatly appreciated.
51 REPLIES 51
Gdetrailer
Fix what you have for now, it WILL be cheaper than buying AND FIXING someone ELSE'S "problem child".
Buying older or slightly newer USED vehicles to replace your problem child will result in more frustration even with different brands. Folks tend to USE their trucks and if they have not replaced front end parts by now, YOU WILL be doing that.
You simply do not know the "history" of someone else's vehicle and that in the long run could cost you more to "fix" than what you have.
For the money you will be tossing out there for those years you could rebuild the entire front end, replace the engine and perhaps even the transmission in your vehicle.
dadwolf2
jaycocamprs wrote:
Either the Dodge or the GM twins with a diesel will do just fine. A 06-07 Duramax with the 6 speed would be nice, but the 5 speed trucks will do fine. I would look at just a bit newer if you go with a gasser, the 6 speed GM is a big improvement over the 4 speed. Your wife is right, you do not want a Ford 6.0 diesel in those years.
X2
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
jaycocamprs
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Engineer9860
7400 GVWR?
Unless you tow regularly in the mountains you can probably survive with another 1/2 ton. Upgrade to a gas 3/4 ton for more capacity/comfort zone.
The only reason you need a diesel for that weight is just if you want one...... And there is nothing wrong with that. If a diesel is what you seek look into the LBZ Duramax. A proven, reliable combo.
In Memoriam: Liberty Belle
45Ricochet
donn0128 wrote:
Any of the 5.9L Cummins equipped Dodges will give you years of reliable service for minimal outlay. The GM Duramax/Allison combination are also reliable well built vehicles. Go drive them and compare cost, ride and comfort, then make a decision. Personally i like my Cummins, 25% fewer moving parts, lower revving and the motor is proven over millions of miles of satisfied owners.
X2
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
OpenRangePullen
Cummins should last longer and parts are every where and are easy to maintain. Tho they are low maintenance.
2013 OpenRange Roamer 395bhs
2022 F350srw Limited, tower
2021 F150 Platinum Hybrid, daily
2002 Accord V6/5spd, project
2014 Kawasaki Concours
donn0128
