dodge_guy
Jul 24, 2015Explorer II
The hub temps will probably be around 100 degrees or so. Compare them side-side, if one is significantly hotter than the other then something needs to be checked.
Yes you want to lube the hitch ball. Metal on metal is not good and will prematurely wear out both the ball and coupler. It's basically a ball joint, and those also have grease in them. I wipe it off about every other trip and reapply a new dab of grease. Same should be done to the points where the WD bars slip into the WD hitch head.
44,031 PostsLatest Activity: May 11, 2025
