JCTSMOM's avatar
JCTSMOM
Unsure where to start with redo of our Sky Cruiser II
We were given a 94 Sky Cruiser and were aware of the water damage, but it's worse than I thought.
The roof is totally rotted, as are the walls in the front and both sides, but the wall where the door is is okay. The floor is okay as are the cabinets, but the bunk board is also rotten. My question is....where do we start? I've removed the Luan and foam panels from the walls, the appliances and the terrible carpeting from the step up to the bunk this far. In an earlier post, I was told that the vertical cabinets are supports in this model, so I haven't touched them. Do I remove the roof completely and start there? If I do that, there's nothing to attach it to! If I start with rebuilding the walls, it's the same scenario.
Also, suggestions for a new roof? It looks like the water is getting in because the wood frame is so rotted, the aluminum shell has pulled apart. The camper sat for a few years out in the open apparently. I'm unsure how to tell what condition the membrane on the roof is. Should I just redo the entire thing or try to patch if needed?
There'll be no kitchen in our redo, but a mini fridge will be installed as will an air conditioner.
Help!! :)
