- tomman58ExplorerLike I said one stop shopping seems to make the most sense as when my DEF info comes on I have a 1000 miles to get it. Pull into most truck stops and do it all at the pump.
- billyray50Explorer
Wild Card wrote:
I only use Peak or fill up at the pump. piece of mind and not worth the problems that can evolve
X2 - Wild_CardExplorerI only use Peak or fill up at the pump. piece of mind and not worth the problems that can evolve
- LIKE2BUILDExplorer
Huntindog wrote:
LIKE2BUILD wrote:
You either got old DEF, or DEF that was replaced with water. It had NOTHING to do with the brand.Ron3rd wrote:
Has anyone used the Wal Mart brand Super Tech DEF? If so, opinions?
Haven't used WAlly brand but I did use another cheap brand. I got repeated check engine lights for insufficient catalyst on a run to Minnesota and back. After that I drained the DEF tank and refilled with Peak Blue DEF. I haven't had a CEL since then.
It could be coincidence, but the few $$ savings isn't worth it to me now.
KJ
ALL DEF is EXACTLY the same.
Yep, most likely old. The box was unopened so age was the most likely culprit. Like I said, it could have just been coincidence or some other factor. But, the track record I've had with Peak, the absence of issues using it, and the minimal cost difference doesn't make the cheap stuff worth the risk.
KJ - Ron3rdExplorer III
tomman58 wrote:
why would anyone pay more than $2.89 a gallon for this stuff????? I've been getting mine from the truck stops for years. There is no magic here in this stuff it is all the same. your truck likely shows you when you are within 1000 miles of needing it so there is plenty of time to get it. Also I've never shopped at a WM and never will.
Yeah, I fill up at the pump too from time to time. The WalMart 2.5 gal jug works out to be $3.15 a gallon, which is the best deal I've found other than the pump. I have no problem shopping at WalMart - tomman58ExplorerOne other thing ................ DEF has a shelf life. Go to truck stop they have it as fresh as possible. 2 years on the shelf and this stuff is useless.
- tomman58Explorerwhy would anyone pay more than $2.89 a gallon for this stuff????? I've been getting mine from the truck stops for years. There is no magic here in this stuff it is all the same. your truck likely shows you when you are within 1000 miles of needing it so there is plenty of time to get it. Also I've never shopped at a WM and never will.
- nevadanickExplorerI have bought alot of them from WalMart that had the crystals around the opening and the seals were not good and never had an issue. Multiple jugs on the shelf were that way.
- HuntindogExplorer
KJ
ALL DEF is EXACTLY the same. - thdExplorerI use the Super Tech DEF. You do have to be careful though, there is a Walmart near me and most of the jugs they have on the shelf usually are just water. You can tell when someone has refilled with water and returned it. Look for crystals around the cap, and ALWAYS take the cap off and check the seal. And use your finger to check the edges of the seal, most of the time the low lifes have tried to re-seal but you can tell its not a good seal.
I have warned the staff at the store of what I have seen, but they didn't seem to interested in it.
The Walmart on the other side of town doesn't seem to have the same low lifes shopping there!
About Travel Trailer Group
44,055 PostsLatest Activity: Dec 23, 2025
