Thanks all for your helpful responses, the fridge is not in the slide as Brian noted. I checked under the vent cover on the roof and cleaned out some pine needles, but it did not make a difference. The rig is a 2021 model, so all should be new. I checked the door seals and they are good. Its as though the fridge is in defrost mode with moisture dripping from the fins inside the refrigerator. The freezer is at -6 and the fridge ranges from 40-60 degrees. I'm going to install fans below the roof vent cover and maybe on the wall cover. Any other ideas?
