- LanceRKeysExplorerBucky, sometimes words have different meanings. Look at the standard features on this trailer and you will see "dovetail" mentioned. Which is the drop at the rear of the trailer to make loading cars easier.
big tex dovetail car hauler
Here is another manufacturer that lists "dovetail" as a standard feature:
gooseneck flatbed dovetail
Using a word differently than someone, doesn't make the use wrong, it is just a different use for the same thing. - buckyExplorer IIWe all can certainly call something anything we want, but sometimes we would be wrong. See clicky.
Dovetail clicky - valhalla360NavigatorFarmers often go out on very rough roads and fields with gooseneck trailers, so they need the extra clearance.
5th wheels rarely see such rough conditions so your standard pickup bed is typically fine. - newman_fulltimeExplorer IIto roll hay off the back easier, for wind to direct under the trailer
- LanceRKeysExplorerBed sloped down at the very back of the truck bed, downhill on a slope seems like a good reason, but if it was necessary I would think a regular truck bed would hit really easily.
I call it a dovetail because when the back of a flatbed trailer does that I call it a dovetail - notevenExplorer IIIDo you mean why does the bed slope down? That’s for maximum clearance to a trailer when making a turn that is a sharp downhill.
Or do you mean why are the corners clipped at 45 deg? That is for clearance to stock trailer landing gear which is often a single heavy leg in the middle.
Or do you mean “dove tail” which is widened out like a Y- like the joint cabinet makers use? Don’t buy one made like that :) Lol - Jim-LindaExplorer IIMost likely it to mount the hitch lower so the trailer will be level when hooked up.
About Travel Trailer Group
44,056 PostsLatest Activity: Jan 12, 2020
