roamlab's avatar
roamlab
What Is On The Bottom of Your Truck Camper?
I am in the middle replacing the floor of my truck camper. The original plywood is terribly rotten and, after years of previous owners patching it, it's time to bite the bullet and start over.
The original base of the TC has three plywood rails running north south. I assume this is for drainage? As I am replacing all wood with a fiberglass-foam composite, I plan to do the same with these, but I'm considering adding a layer of rubber to manage slippage and wear. Thoughts?
What is the bottom of you truck camper made of? Have you done any modifications to it?
