LarryJM wrote:
Two thing IMO to watch out for ...
1. The 14,500 GCWR is more of a performance rating, but IMO going much over around 80% of the GCWR for a vehicle can make for a less than desirable towing experience especially in less than optimum towing conditions.
When people tout the "80% rule of thumb", they usually apply it to the TV's Maximum Trailer Weight rating.
A trailer weight of 7200# and a MTWR of 8900# gives a ratio of 81%.
2. That 895lbs I believe is the receiver rating when using a WD system and the wt. of the WDH (around 100lbs typically) goes against that receiver rating leaving you a dead tongue wt. limit of around 700lbs which using the 12 to 15% of the TT wt. gives you a loaded trailer wt. max of between 4700 (15%) and 5800 (12%).---
Larry, can you provide a link to a credible source which says the weight of the WDH goes against the receiver rating?
You are correct that the weight of the WDH does add to the vertical load on the receiver.
However, the stresses in the receiver are primarily controlled by the pitch-axis torque applied to the receiver.
The pitch-axis torque is primarily controlled by the amount of load transfer required, and that is controlled by tongue weight.
The weight of the WDH does not have a significant effect.
If you are concerned by the amount of vertical force applied to the receiver, you should consider:
1) the weight of the WDH does add to the vertical force on the receiver,
2) the tongue weight does add to the vertical force on the receiver, and
3) the load transferred to the TT's axle is deducted from the vertical force on the receiver.
If you follow Ford's 2006 specification of returning the front end to its unhitched height, you will need to trans fer a load equal to about 25% of the tongue weight to the TT's axles.The load transferred to the TT's axles will be greater than the weight of the WDH.
This means the net vertical force on the receiver actually will be less than the tongue weight.
There's no need to subtract the weight of the WDH from the receiver's tongue weight rating.
Ron
