- Tennessee_NomadExplorerWell, we ultimately went with the Atwood 3500lb from Amazon. It seemed to be a very good price on that particular model. A local RV dealer said it was the Mercedes Benz of power jacks (don't know about that, we'll see) and tried to sell us the same model for $299 plus installation. I'm pretty handy with a wrench and screwdriver so I think I can get it installed. Thanks for all your input and comments. This forum is a great research tool. :D LET'S GO CAMPING!!!
- BarneySExplorer IIIYes, in my opinion it is worth the extra money to get the Atwood. I have had them on my trailers for about the past 20 or 25 years and have never had one fail. The present one is about 10 years old and still workine fine. :)
Barney - tomkaren13ExplorerDo not buy cheap. That saying is true Buy cheap, get cheap. Sorry do not know about the Atwood., we went with the Barker 3500 and could not be happier.
- dontexasExplorerTennesssee_Nomad...... We have the same Nomad 260 that you have. Great trailer and love the rear kitchen. Had ours for a little over a year and use it a lot with no problems at all.
I bought and installed an electric tongue jack when I first bought the trailer. This is about the best investment you can make...... Happy camping - aftermathExplorer IIINice job with the links.
I am not the type that looks for "deals" like the $70 jack. In the long run you usually end up paying more. What kind of guarantee do these have? Are they similar? While I like places like Harbor Freight, I try not to purchase anything that I will have to depend on over a long period of time. - Tennessee_NomadExplorer
- wrvondExplorer II
thomasmnile wrote:
I was wondering about the 'truck lifting' posts......... We've had our TT a year and have never done that to install or remove the trunnion bars on our hitch. Seems applying that kind of force would possibly twist or bend the receiver, not to mention the dealer instructed me on how to hitch/unhitch and lifting or putting that kind of force on anything wasn't part of the procedure.
Depending, of course, on the tongue weight you are dealing with, the WD bars can be under a lot of tension. With the full weight of the camper on the hitch, you will likely have some sag at the rear of the TV. This means that when you snap the chains up, you are lifting that portion of the tongue weight that is causing the sag. This can cause a lot of tension in the WD bars, and actually snapping the hooks into place, then putting your tender little cotton pickers near them in order to insert the locking pins is downright dangerous. By eliminating the sag, you are removing the weight from the bars. Your chains should simply lift into place with little or no tension, making it very easy and safe to insert the locking pins.
As noted, you should not lift the wheels of your TV off the ground. The previous story was relating how not having both the TT and TV on level ground resulted in an unusual (and undesirable) condition.
While dealers are often relied upon for information, I would refer to the manufacturers instructions and follow those over anything a dealer told me.
The manufacturer of my Reese Dual Cam Anti-sway Weight Distribution Hitch, gives very specific instructions on how to install and use the rig. In those instructions are steps that include raising the rear of the TV in order to remove weight from the distribution system while hooking up the chains to the snap hooks. - Tennessee_NomadExplorerThanks for the input... I appreciate it!
- dadmomhExplorerBTW, important lesson learned the hard way....ALWAYS have spare fuses on hand for the electric jack. Don't ask, he wasn't a happy camper!
- sausagekingExplorerI got a 4500 Husky with remotes for christmas, can't wait to install it.
About Travel Trailer Group
44,026 PostsLatest Activity: Mar 01, 2025
