macuser wrote:
Wife and I have NEVER owned an RV but are ready to pull the trigger. Nice thing is, we also donโt have a TV so we get to match our need. We are going to buy a Fifth Wheel with a dry weight between 6500-7500#. Tongue weight will be about 1400#. So, what is the smallest truck we can get WITHOUT putting any undue stress on the TV and having a SAFE pull and of course a SAFE STOP? We do plan on being in the mountains on occasion. Do not want a diesel. Have read about 2007 or newer Tundra 5.7 and Ram 1500 Hemi. We will not be buying new.
Welcome to the forum
Good that you are asking before buying. Many buy first without knowing
the metrics and listen to the salesperson, who is only (generally)
interested in making a sale
Many who bought first before educating themselves too often end up
having to buy higher class TV or smaller trailer. The OEMs and sales folks
love this
First time pickup/SUV/etc owners generally only look at the lowest
class TV, as that is huge compared to their 'car' experiences. Also
confusing is that the bodies (sheetmetal you can see) between the
different classes of TV's look the same from the lowest class (half
ton) to the highest class (1 ton). The difference is underneath the
skin in the frame, drive train, suspension and many etc's
First, decide whether you believe in the OEM ratings/specifications/limits/etc
If not, then do whatever. If still under warranty, note that the OEM
may not provide warranty if they should find out if you went over their
ratings. Many lie and I consider that fraud
If yes, then read up and learn how the OEM's ratings/specifications/limits/etc
work. Many do not understand that in the acronyms (GVWR, GAWR, GCWR, etc)
all have an 'R' in them, which is 'ratings'
Some only come here looking for a 'you are good for it', 'have been
doing that for decades with no problems' or some such and they will
receive many, but note that the only person responsible for the setup
is the driver...not the advisers (would they provide funds to pay for
any over load issue based on their advice?) I do not normally say
'sure you can', nor 'no you can not', but provide the metrics for the
person asking to make up their own minds, as it is they that has to
live with the setup
Here is a diagram that shows how the OEM specifications/ratings/limits/etc
look like in graphical form. That it is a system and to take any one
ratings is out of context. That there is fine print in all OEM specifications/
ratings/limits/etc that modify those numbers
Why it is best to actually weigh your TV and trailer, fully loaded
axle by axle.
Since you do not, then either guess how much they will weigh fully
loaded or use their GVWR (Gross Vehicle Weight Rating...this applies
to the trailer too). That would be the limits for each, the TV and trailer
howmuchcanitow
-Ben
Picture of my rig1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
