Sep-09-2013 01:50 PM
Sep-13-2013 08:21 PM
Bamarickandlisa wrote:
It does not take a professional to replace, pack, grease and adjust bearings.
I'm 56 and have been doing them on different types of trailers since I was about 14.
He clearly is not doing the job you are paying him for.
Sep-13-2013 07:26 PM
Turtle n Peeps wrote:
I set up race cars all time. Extreem camber both + and -. Lots of G force in the turns. Heavy stock cars with slicks that just put a lot of load and abuse on the bearings. I have seen them set up so crazy they are running on the side of the tire. Never seen a bearing at the track or on a trailer fail because of camber.
I have seen home made axels that people have cut in half and widened out and are so far off it's crazy. Lots of tire issues but no bearing failure issues.
I have seen LOTS of bearings fail because they are set up too lose or too tight and no lube but never for camber issues; NEVER, EVER, EVER.
Sep-13-2013 06:14 PM
Sep-13-2013 04:25 PM
Sep-13-2013 01:30 PM
Sep-13-2013 01:29 PM
Barney007 wrote:CKNSLS wrote:Barney007 wrote:
I too have experianced wheel bearing failurs and fires within a 6 month period. First make a claim with the NTHSB. Second I had the repairs completed and the AXLES ALIGNED. A good truck/trailer frame shop can do this work. It will cost around 100+ an axle. In my situation the rear axle was the culprit, camber was -1-5/8" and -1.0" on the other. The axles are now alighned and we will see about the other bearings. The trailer is only two years old and YES I too had the CHINA bearings from the factory.
So the China bearings were not defective in your particular situation since it was the axle(s)?
China bearing had a lot to do with it as well as the alignment, those guys from Cali are ID 10 T's Camber had something to do with it, With negative camber the whell/hub is riding on the outer/outboard bearing (for the guys in cali, it the small one) You want a positive camber for the weight of the trailer be on the inner/inboard (the larger bearing) Yes, a person want to use a good quality grease and tighten to manufacture specs.
Sep-13-2013 12:13 PM
Sep-11-2013 01:42 PM
byways wrote:Lynnmor wrote:Passin Thru wrote:
Buy Timken Bearings. Never lost one of them yet. Pulled trailers lots of miles. Tighten them down until the wheel wont turn and back off 1/4 turn.
Here is an example of incorrect adjustment. You might damage the bearings by tightening them that much. The 1/4 turn is not correct.
Elsewhere, someone mentioned SKF bearings. SKF manufactures many bearings in China.
The OP doesn't want to be involved with the maintainence of his wheel bearings. All I have to say is; good luck with that.
Is that what I wrote? I performed maintenance EXACTLY as the manufacturer suggested (Lippert) and at the correct intervals. Since you're knowledgable in this, why don't you post the correct version for all to see?
Sep-11-2013 01:32 PM
Leaf-Peeper wrote:byways wrote:
... I KNOW the axles were properly lubricated on both occasions (prior to failure). This recent bearing/axle has less than 3,000 miles on it, and is less than 1 year old.
What causes this?
In a previous and somewhat unrewarding career, I used replace damaged axle housing spindles on over the road trucks, tractors and trailers. The bearing failures in these instances were so severe, the spindle would end up being heavily damaged. Sometimes they got so hot, they'd catch on fire.
Based on my experience, if the bearings were adequately lubricated, there's a high probability the failure could have been caused by the spindle nut being installed too tightly.
My guess is that in about 75% of the failures I saw, the truck or trailer had recently had the brakes serviced (which required the removal of bearings). I believe in most instances the bearings were probably adequately lubricated, but the failures likely occurred because spindle nut was installed too tight, which resulted in insufficient bearing clearance.
I recall an instance where a concrete pumping truck (tandem drive axles) had gotten just a few miles from the service shop after having it's brakes serviced, it had ruined a drive axle housing spindle, for which the road service guy chained-up so it could be driven back to the shop. Before the truck could make it back those few miles to the shop, the other spindle on the same side of the had also failed. Turns out there were two guys involved doing the brake service... one worked the right side of the truck, another on the left side of the truck. Inspection of the spindles on the opposite side of the truck showed no signs of wear or damage. One guy seemed to know what he was doing, the other guy apparently did not.
In a snapshot, here's how I tighten our trailer's spindle nuts (your results may vary):
I'll rotate the hub/drum when tightening the spindle nut to ensure the bearings are able to seat themselves (often done using a pair of channel-locks). After it's snug and without any rotation of the hub, I'll loosen the nut and then retighten it just finger tight. In most instances, the nut will have to be backed off a bit further to allow installation of the cotter pin. After assembly and the wheel/tire is back on, I do a simple lift test... momentarily lift up the bottom/outside area of the tire to be sure there is some radial play detectable.
Sep-11-2013 01:28 PM
Sep-10-2013 04:25 PM
Sep-10-2013 03:55 PM
What causes this?
Sep-10-2013 03:49 PM
byways wrote:I would still call the guy to pick his brain on what happened.
Sorry for the confusion. When the axles were installed, the installer (a trailer shop) indicated he personally hand packed and adjusted the bearings. That is the only way I know they were done correctly. I am not a professional, that is why I hired a professional to do the job. My knowledge was based on the reputation of someone else.
Sep-10-2013 03:07 PM
Barney007 wrote:
I too have experianced wheel bearing failurs and fires within a 6 month period. First make a claim with the NTHSB. Second I had the repairs completed and the AXLES ALIGNED. A good truck/trailer frame shop can do this work. It will cosr around 100+ an axle. In my situation the rear axle was the culprit, camber was -1-5/8" and -1.0" on the other. The axles are now alighned and we will see about the other bearings. The trailer is only two years old and YES I too had the CHINA bearings from the factory.
