LASilvey's avatar
LASilvey
Whiten tub/shower stall
After 10 years, it would appear that our tub/shower is starting to become a bit yellow. Just wondering if anyone has ideas on how to whiten it up? Are there any cleaning products that might work? Thanks so much !
  • I'd try oxy-clean... the paste kind that you get in a tub... I'd put it on like car wax but I'd wet the tub down first... then apply it. Let it sit for a bit and then rinse it off.
    I use a UV protectant on my shower/tub walls (NOT THE FLOOR - it would be way too slippery) to keep the walls from yellowing. Protect-All.... ARMOR-ALL ... anything like that will work.
  • Try straight white vinegar. You can buy it in gallon jugs. Let it soak for several hours. You can wet a towell and drape that over places you can't soak.
