โJan-30-2016 05:16 AM
โJan-30-2016 06:30 AM
RoyBell wrote:Greene728 wrote:
I'm not sure where you are getting your information regarding the Big 3 and their new gas engines and taking a step backwards. When comparing them with your Tundra ( which admittedly is a fine truck for it's intended purpose ) either of them with gas engine's in 3/4 or better yet 1 ton configuration will out tow the day lights out of your Tundra, and get comparable mpg while doing it. It's far more than just engine HP and torque numbers. It's bigger frame, bigger brakes, different gearing, better transmission, higher payload, better suspension, etc... No stepping backwards at all! And I'd even say that for the weight your towing and being a DD that the gas would be your best bet. Now if your planning to upgrade your RV in the future and don't mind the extra costs associated with the diesel then go for it. And yes, I'm speaking from first hand experience. Had a 2012 F-250 with the 6.2 Gasser and pull a 5th at around 9500# loaded. Truck did fine other than less than stellar gas mileage when towing which is to be expected. I know have the truck in my signature that the 250 was traded in on and it is also my DD. Towing and fuel mileage between the 2 is no comparison and apples to oranges. I had diesels up until the gas 250 since 2003 and just missed being in a diesel trucks and was just not able to adjust to the gas engine towing. So far absolutely no issues and no regrets in 3.5 month's and 3500 miles.
Re-read my post. I said step back in power.
Toyota 5.7: 381hp 5600 rpm/ 401tq 3600 rpm
GM 6.0: 360hp 5400 rpm/ 380tq 4200 rpm
Ford 6.2: 385hp 5500 rpm/405tq 4500 rpm
Dodge 6.4: 410hp 5600rpm/ 429 tq 4000 rpm
They are all right in the same ball park, but the Dodge being the highest. But, Toyotas 5.7 makes torque lower than all of them. Then add the heavier curb weight of the 3/4 ton and performance will be down compared to what I got now which , to me, is not acceptable.
โJan-30-2016 06:28 AM
kzspree320 wrote:
I had a 2008 Ram 2500 CTD and recently traded in for a 2015 Ram 2500 with CTD. I love the way the Cummins pulls our 12K loaded fifth wheel. It's my daily driver and does a fine job. It is true that diesel maintenance is higher and repairs, while seldom needed, are more expensive.
If you really want an F250, and are pulling under 8K in your case, why not get the 6.2 gas? If you research the transmission gearing (not axle) on your Tundra, as memory serves me, you would find that the towing power is in no way comparable to the F250 with the 6.2 gas and 4.30 rear end (which is J2807 rated to tow over 15K).
If you think you may be towing heavier, want the additional power (like me), or want the better towing MPG (again like me), then the diesel is a fine way to go. I chose the Ram and Cummins because it still has the CP3 fuel pump and 2 fuel filters, and based on my prior truck the towing and reliability was great.
The CP4 fuel pump used on the Ford 6.7 and Duramax diesels create a high repair cost risk I didn't want. That said, I realize the failure rate may be low, but it's a risk I didn't want. If you don't know what I'm referring to, do a little research. Look at user Ricatic threads on his truck. This failure is not that common, but it's expensive.
Again, I think my diesel is a fine daily driver. Good luck. Keith
โJan-30-2016 06:20 AM
โJan-30-2016 06:17 AM
therink wrote:RoyBell wrote:
Currently doing about 6-8 trips a year. Living in Chicago cuts our season pretty short.
I should note I am not partial to any of the big 3 currently... I am looking to buy new, so it sounds like they all have a headache of emissions ****. All you need to do is google diesel issues and you get presented with a plethora of emissions issues.
The 5.7 in the Tundra seems OK on power, but could use more. If I decide to keep it, I will be putting a TRD supercharger on it, which would bring me close to diesel power without the emissions headaches. I would still have the payload issue though.
Keep in mind that the Internet is a very biased place for negative criticism regarding anything sold to the consumer. Google RV problems and you get the same negative posts. For each unhappy diesel owner, there are millions of happy ones.
โJan-30-2016 06:12 AM
โJan-30-2016 05:55 AM
โJan-30-2016 05:54 AM
โJan-30-2016 05:53 AM
โJan-30-2016 05:52 AM
โJan-30-2016 05:51 AM
โJan-30-2016 05:49 AM
โJan-30-2016 05:48 AM
โJan-30-2016 05:37 AM
โJan-30-2016 05:30 AM
