BlkCaribou's avatar
BlkCaribou
Who has insights on a 15K BTU AIRCOMMAND RV A/C & HEAT PUMP.
I am considering buying 15k BTU AIRCOMMAND RV A/C & HEAT PUMP, COMPLETE, DUCTED unit for my truck camper.
http://www.rvsupplywarehouse.com/rv-air-conditioners/15k-btu-aircommand-rv-a-c-heat-pump-complete-ducted/
1. Anyone have personal experience with this unit?
2. Is 15K a good fit for my camper? installed now is a Coleman-Mach Air 8632-870 which I believe is 13.5 btu I have a 99 Fleetwood Caribou 11' 6" which I've owned 5 years now and I'm pretty sure it's a factory installed unit.
3. I believe, or maybe hope, it will work with the exsisting ducting and rooftop cut out. Any insight or experience with this would be great!
3. The onbaord gen, a genrac34, can it run a 15k unit?
Thanks!
  • BlkCaribou, I stepped on my tongue, er finger. I meant to say cycle. I am referring to the compressor cycling on and off because it has made temp? From what I have read, it will cycle more. It is also harder on the compressor.
    As Victory402 posted, the cycling will not allow the A/C to properly remove the humidity from the air.
  • An AC unit that is over sized will not run long enough to remove the humidity from the air.
  • Hey Reddog1,
    thanks for your reply. When you say recycle are you speaking of the compressor cycling on and off because it has made temp? I would think it would do that less.
  • In my opinion, it is too big for your TC. It will recycle often. This is not from my personal experience, but what I have read many times. I too have a 11.5 foot TC, with a 9,200 btu A/C. It geets the TC really cool.
