windhorse
Nov 18, 2021Explorer
Why whine, heater question
Hi, as the lucky owner of a venerable 1996 Lance Legend 500 truck camper, I am very happy to get my truck back on the road again in Arizona after a looooong time - 18 months! - in storage (due to the pandemic).
I am even more happy that despite such a long time without starting up or moving the old truck, a 2003 Chevy Silverado, it only needed a couple of new batteries and was ready to roll again.
The camper also works very fine, even the fridge and stove, proving old is gold! But I have encountered two minor problems and would welcome any advice you may have about what to do about them.
First, the heater, which works fine, warming up the whole camper very fast, however when I turn it on the motor of the heater that is behind a panel below the sink makes quite a high-pitched whining noise - more like a screech actually - as it starts up before settling down to its normal purr after a minute or two. So would like to ask for your guesstimate as to what that noise could be?
Do you reckon the heater motor making a noise when starting up signals that it is about to kick the bucket, or just needs oil or servicing, and if the latter rather than the former, does this being an older model camper sound like a big problem that requires a specialist rv technician, rare as hen's teeth parts and big job to fix, or is it something common that most likely can be easily fixed?
Apart from this, the only other issue is a few drips coming out the bottom of the dump pipe, which I figure may have something to do with rubber seals or gaskets needing to be replaced somewhere up in the plumbing, and am also uncertain same as above if this is likely to be a small or big complicated job to fix.
Whatever happens, neither of these issues has stopped me and my partner from getting on the move again, which we are extremely happy about, feeling very lucky to be able to do so.
However we will sleep better at night knowing what that screeching heater motor and dripping dump pipe could be, so will appreciate very much any opinion or advice you may be able to give?
