1buda
Nov 26, 2013Explorer
Winter camping
Dumb question. We plan on camping on Thanksgiving weekend. What keeps the city water hose from freezing up at the camp site?
2012Coleman wrote:
OK - don't mean to be cynical, but someone from Pittsburg needs advice on how to keep something from freezing?
I'm in central Ohio right now, and just a heads up...it's cold.
I've got our hose wrapped in aluminum tape insulation, then have the heat tape (mentioned already on this tread) wrapped throughout the hose, taped every so often, then I have the hose wrapped in the foam pipe insulation, duct tape on the seams.
If you're only going to be a short while, I'd suggest just filling your tank and taking it easy on your water consumption. Otherwise, depending on where you are in Ohio, you might be able to get away with just spending $10 on foam pipe insulation at the hardware store and crossing your fingers.
Hope this helps!
1buda wrote:lat471 wrote:
Go further south.
I'd like to. I have in-laws coming in from Nashville, meeting in Ohio.
1buda wrote:Keeping it inside and not using it.
lat471 wrote:
Go further south.
