LUVTOTRKCP's avatar
LUVTOTRKCP
Winter Storage Question
We have our camper stored in a wonderful heated building. I have not taken the camper off the truck or put the jacks down. We put it in about November 5 and will take it out in April. My qestion is what about the tires. With the camper on they squat a little, will they have a flat spot in the spring? Would I be wise to drop the jacks and take some weight off the truck. Or am I being silly, the tires are Michelin's, the truck is a dully, the camper weighs about 5000#
Thanks for your input
  • Thanks everyone
    I have decided to leave it the way it is. Even if i do get a flat spot it will be tempory. I appreciate all your input.
    Great Website!!!!!!!!!!!!
    Get out and camp.
    Life can be over in a heartbeat.
    Enjoy it while you can, (and fuel is cheaper now) Go Far!!!!!!
    Thanks
  • With old bias ply tires of years back there could be problems with flat spotting them but with radials I sure wouldn't worry about it.
  • I'd be afraid of forgetting they and down and pulling the truck foward a few feet..
    If the truck is on pavement/gravel, I wouldn't worry about it.
    If its on dirt, get some 3/4" plywood and cut 2x2 sheets to park the tires on, and not worry about it. Check the pressure every couple of months if you're concerend.
  • Never heard of this happening, but it is possible if you let the jack downs while it is still attached to the truck for long term storage, and you get a flat, it could damage your tie down points on your camper. Maybe disconnect the camper from the truck and then take some weight off the truck?
  • Bernard,
    I would be more concerned with rodents. They love nice spots where they can have a family- don't ask me how we know.....
    Tires- once they have a few miles to warm up shouldn't be a concern. Think about how often semi-truck trailers sit in very cold temps for a few weeks then are running at 65 within a few minutes. More of a concern with bias ply tires, not so much with radials.
    John
  • Wagonqueen Truckster wrote:
    Personally I would put down the jacks and take some weight off the truck. But then again, I am a big afraidy cat about everything.
    X2
    That's what I did when I'd leave mine on for a couple of months.
    Bill
  • Personally I would put down the jacks and take some weight off the truck. But then again, I am a big afraidy cat about everything.
