Wire Size
Don___Barb_Bogu
We tow our 5 th wheel with a 1999 Ford F250 Diesel (The good one a 7.3 ) I recently went on O-2 . The O-2 generator uses Lithium Batteries, and comes with a plug so the batteries will remain charged while traveling. Have herd of some fires because the Automotive wires were to small and overheated. I figure we need at least 14 Ga. wire. These batteries are 17 volt, so that is a heck of a pull on a 12 volt system. I have a new alt. and batteries on the truck. I may have to replace a wire that has never ben used....
18 REPLIES 18
time2roll
Actually 17 volt battery will feed a 12 volt system. You may need an inverter to plug in the adapter. Or do you have a DC/DC converter to supply 17 volts from 12? Post the amp rating of the charging adapter for a wire size recommendation. Otherwise my guess is #8 minimum.
lawrosa
Are you plugging into a cigarette lighter in the truck?
Whats the model of the o2 so we can get the specs..
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
donn0128
Oxygen.
You need to look on the unit and determine what the watt/amp draw it is rated for.
wanderingbob
How many amps ? 14 Ga. wire sounds small to me but I do not know what an O-2 is ?
