bj3759's avatar
bj3759
Wolf Creek 890 Water Pump
Looks like my 2021 Wold Creek 890 water pump did not survive the winter. I have spent the last hour trying to actually find it. Any one know where the water pump is installed?
  • These pumps will dry out over the winter and not create enough of a seal when started in the spring. Simply take the winterizing hose and pour some water into it, turn the valve to allow the pump to suck it in and then turn the valve back to pull from the fresh water tank. It should regain its prime and work fine.
    Now if it is leaking because it was not properly winterized, well……
  • MORSNOW wrote:
    Did you winterize the water system with antifreeze? The winterizing hose is right next to the pump. It should be up front right by the fresh tank (either under the step or right next to it).
    This.
  • MORSNOW's avatar
    MORSNOW
    Navigator III
  • It is in the left cabinet next to the cab over steps.
