RickW
May 06, 2023Explorer III
SkiBumAt50 wrote:Grit dog wrote:
^I get it. Whatever works best for you is what works best.
The big thing with moisture is volume introduced via external stuff (the wet ski gear) and the lack of good air circulation. The forced air furnace (mouse turd burner lol) does a lot to dry the air but trust me. Few people for a few days in cold weather in a TC will be a challenge to keep humidity and condensation under control. You can. It’s not prohibitive, just a bit of a challenge.
You can charge from the truck somewhat efficiently with a good size DCDC charger.
Still, your engineer sense should guide you from over complicating things like plumbing into the truck fuel tank. Besides those little heaters only use like a half gallon of diesel a day or something minuscule. Nothing a little fuel can and 5 min a day can’t keep full.
If I have any control over it I WILL be doing very similar to you again in the future. And having run a couple TCs thru the gamut from driving to AK to outrunning tornados in the Midwest and boonie docking in the Rockies and cascades, what you’re planning is a great setup.
Cheers!
I understand humidity. That's specifically why I was asking about the dehumidify feature on the new Truma AC that Lance is using. I was wondering if it was like my Canadian friends who use their AC in the winter (Run AC in the winter). When I asked my local dealer guy he had no idea. But if it functions that way? That's a game changer.
Worst case I think a small air-to-air heat exchanger could be fabbed to do air exchange and dry out the camper. Making it look good and fit somewhere is the only problem.
See this post for info on an air to air heat exchanger I made to fit in the sliding window under the bed. Sorry, photos were deleted by photo host. I have used it off and on for the past 10 years.
Heat exchanger for TC
About Truck Camper Group
225 PostsLatest Activity: Jan 25, 2025
