sue_t
Jul 26, 2013Explorer
Also check to see if your axles have become bent.
The axles normally have a slight upward camber, highest point in the middle.
When one of our axles bent, the axle looked straight while on the fifth wheel. When we took it off to replace it, the bend was obvious ... off to one side.
Replaced both axles with heavier duty axles when we did this repair. The original axles were rated 3,500 lbs each and now they're 4,000 lbs each.
About Bucket List Trips
13,488 PostsLatest Activity: Jul 25, 2025
