- Dandy_DanExplorer
Chuck_thehammer wrote:
Thank You.. we depart tomorrow.
I have a Garmin 770lmthd.. hope it helps, and paper maps.
71 to 65... aka Louisville. and 264 around.
If you can gauge your time so as not rush hour traffic, I would go straight though. I went through Cinci last Tuesday stayin on 75 Northbound. If you are coming down I 71 it might be a **** shoot which way is the best. Good Luck and Safe Travels. - rbtgloveExplorerstraight through except late Friday afternoons in summer
- Chuck_thehammerExplorerThank You.. we depart tomorrow.
71 to 65... aka Louisville. and 264 around. - bigred1cavExplorerstraight through at those times
Cinn you need to n
know where you are going after leaving Cinn I 71 and I 75 can confuse. - camperforlifeExplorer
Rangerman40 wrote:
Having lived in Ohio my entire life every time I pull my TT I go straight through. 275 in cincy takes you waaaaay out of the way. But as everyone else says it depends on the time of day. If it's rush hour you are screwed either way in both cities.
What he said ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
I drive both often and concur. - Chuck_thehammerExplorerNo one talked about major construction on or around both cities.
that in its self is a good thing. 14 days and out of here. - MARKW8ExplorerThru Columbus but around Cincy.Not a fan of the river bridge there.
Mark - padre1944ExplorerI always use bypasses in a car or pulling RV. Much less stress.
- Rangerman40ExplorerHaving lived in Ohio my entire life every time I pull my TT I go straight through. 275 in cincy takes you waaaaay out of the way. But as everyone else says it depends on the time of day. If it's rush hour you are screwed either way in both cities.
- midnightsadieExplorer III,ve gone straight threw col and though it was just fine, and shorter. day time about 9,am. cin I used the by pass and had no problem. I,m in the canton ohio area.small class C.pulling a 17ft boat.
About Bucket List Trips
13,488 PostsLatest Activity: Jan 17, 2025
