edbehnke's avatar
edbehnke
Diesel Fuel for newer diesels
How are people dealing with the fuel issue in Mexico?
I have a 2015 Ford F350 and requires the ULSD fuel. I have issues already in the states with the darn DPF/CAT system.
Any thoughts would be helpful, I'd like to drive down to Mazatlan again.
  • The president of mexico would disagree with you. Pemex has a public statement of the areas that will receive ulsd from Pemex. I dont think that pv is one of those areas. Your expetience is o ly pnr vehicle. There are others that will have similar experiences
    But I would not try it in a Mercedes powered vehicle or a 500 hp plus motorhome
    I would also worry about long term engine problems. How about you buy a 2020 pu and see the results. You can continue using any fuel as youdont have much to lose. A person with a new high dollar vehicle might think differently . Ed Behnke is a long time member and he should not risk damage to his vehicle because one petsontells him it is ok
    Gollowing the recomendations of every vehicle mfr
    He risks nothing
    There is a reason why the engineers have nade thos recommendations
    G M will void any guarantees of the emission and fuel systems if they suspect you are using non ulsd No drivability complaints will be warranteed .
    A notation is made against your vin and remains with the vehicle.
    Moisheh
  • The first thing you need to do is to disregard the opinions
    of the nay-sayers who are blowing smoke on a topic they have no actual experience with, and look for information from people with verifiable actual experience. I have a 2013 Chev 3500HD that has travelled to Puerto Vallarta every year since it was new. That's SEVEN trips to PV and back, and I have had ZERO fuel-related issues. I haul a 5th there and back, and I use my truck as a daily driver for the 5 months I spend there each year. Certainly there are a few little things you need to do to avoid problems, the most important of which is to make sure your truck gets up to full operating temperature each time you drive it, and also don't let it sit and idle for any length of time. Letting it sit and idle for a lengthy time will bring on the Check Engine light even back in the US or Canada using ULSD. Also don't believe the nay-sayers who spout their opinions
    that ULSD is not available anywhere but at the border. I have a Pemex Delivery Report all the way back in 2017 showing ULSD being delivered to stations in PV and my friend who provided this to me assures me that nothing has changed since then. Opinions are worthless, actual experience is what you need to look for.
  • No mfr. Is goingto tell you that lsd is alright. They dont wa nt the liability
    Some sysrems in pu trucks are ok with the forbiden fuel. Some not. The HD systems in
    Motorhomes may give you problems
    Mercedes powered vans will likely go into limp mode. All arco stations have usa ulsd fuel. The rest probably do not except near the border. Some people use the Mexican fuel
    But you do not want to damage your dpf or the sensors.
  • I would ask the manufacturer of your vehicle. It may simply be a U.S. regulation that requires them to state that only ULSD can be used in that vehicle for emissions purposes. The vehicle may be perfectly capable of processing regular diesel.
  • It is not that long a trip, you should be ok with any diesel for a few tanks.
    I would not count on getting ULSD, you might but it will be hit and miss.
    Even the stations that say they import all their fuel from the USA doesn't make that fuel the same as the USA. Mexico gets some of their LSD from the USA.
