_en_Plain_Air_'s avatar
Mar 01, 2014
Need buying decision help
We will be buying a small (24-25') Class C this year, fully acquainting ourselves with it, then head to Alaska Mid-May 2015 for 'the season' or until we get sick of it and want to come home. After Alaska, we will use the unit for lower 48 trips, maintaining our home base. So ... the question relates to how banged up the unit will get on the Alaska trip. If what I read about rocks, frost heaves etc is true ... would we be better off buying a 'gently' used unit, rather than a new unit? This would assume we can find a used unit with an acceptable floor plan. What has your experience been in the unit wear and tear of the unit in Alaska compared to lower 48 travels? Thanks for your thoughts !!
  • Thank you for your insight. I can cross THAT concern off my list. The search continues. Can't wait for the 2015 models to start coming out.
  • It mostly depends on the driver. The road is not moving, just your vehicle. Drive at a speed appropriate to road conditions and all should be fine with new or used. Slow down and then slow down some more, remembering you are on vacation. Many of the horror stories you will hear are just exagerations from some that like to make themselves seem more adventuresome. Just telling someone you drove all the way to Alaska and didn't break anything, isn't much of a story..
    The bigger rigs seem to have more issues, especially some of the large diesel pushers, that isolate the driver from much of the road sounds. Now the very experienced DP drivers don't have many problems with road damage, because they have developed a good feel for their RV and know when they need to back off and slow down.
    Over the years I have done just as much damage to my rigs driving in the lower 48 as I have on the Alaska Highway. Colorado roads have caused me more cracked glass than Alaska. Last trip, 2011, some unseen road debris kicked up and bent one of my truck camper tie downs, in southern Alberta, on a nice highway. Stopped at a shop in Montana and bought a new tie down.
    As mentioned above, just plan on normal maintenance as it is a long trip for most of us. I plan on about 3 oil and filter changes with a lube, plan on wearing about 1/3 or 1/4 of the tread off a new set of tires, may change the air filter once, because of bugs, tree fuzz, etc. I put 1/4 inch hardware cloth behind the grill to help keep the radiator clean, sometime a screen on the outside of the grill if I can get by without over heating the engine. Doing this currently on my Chevy truck instead of the hardware cloth.
    A mid sized Class C is a nice rig to take on the trip. Over the years we have made 5 or 6 round trips with a 24/25 ft C. The last four round trips have been in a truck camper. We just take whatever we own and with just my wife and me, it works fine. However we are considering taking our 5 the wheel next time, whenever that might be.
  • Did 13,000 miles on Alaska trip in 2012 in 2008 Hitchhiker II. Suffered no damage at all, not even a cracked windshield on pickup. No flat tires. HOWEVER, I was careful to slow way-way down where frost heaves, uneven pavement were present.
